03-06-2018 10:22 AM
Hello Canon Community!
I have an older camcorder (HG20). I used to use it a lot, but have not used it in some time. Anywho, I used it the other day for the first time in a year (or two?) and I am unable to import video from the camcorder into iMovie. I did a couple of different things, but had no luck.
First, I just dragged and dropped the files (AVCHD) from the camcorder onto my desktop. Even though they kind of open, they take forever to import into iMovie. I gave it at least 2 hours the other day (and the status bar did not change) before I gave up.
Second, I tried directly importing from the camera to iMovie. I let it run overnight, with no change in the status bar before quitting iMovie. (Even though the movie did appear, I could not edit it, and it was very choppy).
Any help would be greatly appreciated!
Mac OS is MacOS High Sierra (10.13.3). MBP 17 inch, late 2011.
- Jon
03-06-2018 03:16 PM
Are the videos stored on the internal memory or an SD card? When you dragged and dropped did you drag the entire folder and not just the contents of the folder? You can download MPEG Streamclip and use it to view the files or at least the mp4 files.
03-06-2018 04:00 PM
They are stored internally. I dragged the entire file onto my desktop. I am hearing, through all this research, that OSX High Sierra is unable to read these file types...
03-06-2018 04:09 PM
Are they .MTS or .mp4 files?
03-06-2018 04:12 PM - edited 03-06-2018 04:12 PM
Yes, there are .MTS files. I can open in VLC but for some reason am unable to convert to .MOV. I am currently trying an application called HandBrake to do the conversion.
I've had this camcorder for more than 5 years and never had a problem until the updated OS!
I will let you know how HandBrake works out for me!
03-06-2018 04:48 PM
HandBrake worked beautifully. Problem solved!
03-06-2018 05:28 PM
Good choice, Handbrake is good. I also use MPEG Streamclip from Squared 5.
