01-02-2013 03:59 PM
12-16-2014 02:15 PM - edited 12-16-2014 02:17 PM
Solution Summary
Steps to Resolve Speedlite 600EX-RT Low/Change Battery Issue:
Details
After recently purchasing a new Canon 600EX-RT in preparation for a family portrait session, I was eager to get the Speedlite out of the packaging and onto a stand for some test shots before packing up and heading off for a weekend with my extended family.
I grabbed a package of fresh batteries, loaded (4) AA's, secured the battery cover, attached the provided SCH-E1 Color Filter Holder and powered on the Speedlite expecting to see the default factory settings on the 600EX-RT's main LCD display.
Instead I was greeted with a blank LCD and the Low/Change Battery symbol.
I was fairly sure that the batteries that I'd selected were unused, but I usually unpack batteries from their shipping material and add them to a larger container of batteries, so it was possible that used batteries had somehow made their way into the group or that some number of the batteries were simply too old. I set aside the batteries in question and tried another group of four batteries.
I was more than a little disappointed when I was again greeted with the Low/Change Battery symbol. I was fairly certain at this point that the batteries were not the issue, but just be sure I tried a third set of batteries with the same result.
I quickly searched for an online resource that might help me troubleshoot and resolve the issue and found this Canon Support forum thread.
The problem state and the proposed resolutions seem to be inconsistent and involve variations of some or all of the following:
Unfortunately, none of the proposed solutions resolved the issue for me. So I gave Canon support a call and to see if this was a known issue.
I described the behavior to the support engineer and at first he too was stumped, suggesting that perhaps this was a defective device. He offered me several options for either returning or repairing my new 600EX-RT.
I was hoping for a more immediate resolution AND based on the large number of people reporting this same behavior (here in this thread) I suspected that there might be a Canon support advisory (perhaps only available to Canon support personnel) with information describing the issue along with a resolution that did not involve returning or repairing the device.
I asked the support engineer to check and he kindly agreed. After a few minutes on hold he came back and said there was in fact a support advisory that described a similar problem, but it involved the color filter holder. As previously mentioned, I had installed the color filter holder shortly after unboxing the flash.
I was dubious at first that the filter holder would cause the Speedlite to malfunction, but hoped he was right.
I performed the steps as indicated and the Speedlite 600EX-RT powered on correctly. I placed the filter holder back on the device and power-cycled the flash a few more times, and each time the Speedlite came back up as expected.
Upon closer inspection you see sensors near the top of the flash unit and just underneath the bottom clasp of the color filter holder, as well as what appears to be a small magnet in the bottom clasp of the filter holder. These sensors are used by the EOS system to determine when the filter holder is attached to the flash unit and assist in white balance calculations when using Canon supplied filters.
For a more detailed explanation of the color filter's form and functions alongside an EOS camera, google 'Speedlite 600EX-RT SCH-E1 review'.
For a copy of the advisory google 'Canon Issues Speedlite 600EX-RT Product Advisory'
01-02-2013 04:13 PM
01-02-2013 04:39 PM
01-02-2013 05:06 PM
03-20-2013 06:24 PM
04-09-2013 04:01 PM
just received my new 600-EXRT... directly from canon.
and i get the same problem as you guys had.
i also though there might be some trick, but closing the battery cover while the flash is on ON with the batteries inside doesn't work.
i get the symbol with a crossed out battery - which tells me that the unit IS getting power from somewhere, how else could it display the symbol...
04-09-2013 10:13 PM
04-10-2013 12:03 AM
04-10-2013 12:05 AM
04-10-2013 12:20 AM
