08-25-2023
11:15 AM
11:19 AM
I'm hoping someone can help.
I've just bought a Canon 430EX III-RT and for the most part I'm very impressed with this speedlight. However, when I try to set up the AF-assist IR beam both on and off my camera (Canon 90D) it won't work. I've gone into the sub-menu P.Fn 05 and selected "1". When I back out, however, the icon shown is for the standard flash, not the specific AF-assist IR icon. The red IR will not function. I have no problems with the master-slave off-camera flash function which I think is great.
Has anyone else had this issue? I hope it is just a set-up error on my part. Every other function of this speedlight appears to function as required.
I don't do much flash photography but I never had this problem with my Canon 380EX which unfortunately gave up (finally) after 25 years of faithful service.
I look forward to any assistance provided.
Thank you.
08-26-2023 12:14 PM
Hi Bob,
"Are you trying the IR beam with the flash mounted on the camera or not? It will only function when mounted on the camera." - I am only using the flash mounted and locked on the hotshoe.
"Also, are the in-camera flash settings set for IR firing? It can be disabled via the camera menu also."
I've selected <Flash control>
<External flash C.Fn setting>
8 /A/F-assist beam firing "0 - Enabled"
"Besides checking the icon on the flash, have you actually tried it on camera to see if it lights up red in the front of the flash with your lens cap on and pressing the shutter button?" yes, but with no success.
I'm mystified, to be honest. Surely the correct icon would appear in the LCD after setting the AF-assist on the flash unit, wouldn't you think. That, along with the past two days trying to get it to function, would suggest there is a malfunction.
I appreciate your taking the time to assist.
F
08-26-2023 12:18 PM
"Is any IR Beam projected at all from the speedlite. No IR Beam at all or Intermittent Flash Firing. Or NO AF Assist Beam projection AT ALL. When the camera is set to center point AF with IR set."
Nothing.
08-26-2023 12:22 PM
The AF Assist Beam doesn't work with AI Servo. Only One Shot and AI Focus ONLY.
08-26-2023 12:25 PM
That's if you set the camera to "Disable AF Assist Beam". You can't control Speedlite personal functions from the camera menu. You can only control speedlite Custom Functions. You also can't control the AF Assist Beam projection from the camera menu. That can only be controlled from the speedlite.
08-26-2023 12:28 PM
Is the camera set to AI Servo. The AF Assist Beam won't be projected then. Use One Shot or AI Focus.
08-26-2023 12:28 PM
What is the P.Fn-05 (personal function #5) in the flash menu? It should be set to 1 for the IR focus assist.
08-26-2023 12:29 PM
Yes, I know.
08-26-2023 12:29 PM
Also note that the AF Assist Beam doesn't work with the camera set to AI Servo. It only works with AI Focus or One Shot.
08-26-2023 12:33 PM
He mentions not seeing an icon for IR assist, the only place I know of an icon displayed is in personal functions 5. By the way, I have this flash and am familiar with the settings. We should concentrate on helping the OP.
08-26-2023 12:41 PM - edited 08-26-2023 12:43 PM
The icon on the main flash LCD screen doesn't show if the IR assist is enabled or not. In PF.n-05 does show the IR assist icon. deebatman316 raises a good point, are you using AF servo focus mode on the camera? That mode prevents the IR beam firing as well.
