Speedlite 430EX II Compatibility with DSLR
JFG1976
Does anyone know if I can connect a speed light to a canon markiii? I have both but I can’t connect the light to the camera with a speed light off the camera. Please help
7 REPLIES 7
SamanthaW
Moderator
Moderator
Hi there!
We have several cameras with a mark iii option, can you please be more specific?
rs-eos
Also would be helpful to understand how you want to control that flash.  You mention "off the camera", so if the 430 EX II is off camera, it would need to be controlled either optically (a second flash mounted on your camera), or via a sync cable.  The Mark II version of the 430 EX lacks radio control like the Mark III version does.  So with a Mark III version, you'd have additional options in controlling it.
Ricky
RaymondSchwage
Any update?
Update to what? There was not enough question there. If you have a specific issue, ask away.
@RaymondSchwage wrote:
Any update?
The OP never replied with the model of this camera.  It seems the thread was abandoned.
Afzal_BG_BR_UK
Enthusiast
You can successfully use your Canon flashgun with your Canon camera by connecting the two together either:-
1.) physically attach the flashgun directly onto the hot-shoe mount of your camera. OR, you can…
2.) connect a compatible remote Trigger directly onto your camera hot-shoe mount AND then connect the respective Receiver to your flashgun. This allows for Off-Camera Flash - OCF. Freedom of light positioning for artistic and creative effects. (You are now not limited to using a single flashgun, buy additional flashguns with additional receivers and take your photographic journey to a whole new level.
Note1: How - confirm your camera Flash sync speed and ensure your flashgun and camera settings reflect the same.
Note2:- if your Canon flashgun supports the “Master/Slave” feature, you can have one flashgun mounted and another set OCF positioned as/where you want!
Cameras:- 7Dii & (x2 40D)
EF:- 100mm f/2.8 macro, 50mm f/1.8, 24mm f/2.8
EF-s:- 55-250mm, 10-22mm, 18-55mm
Flashes:- x4 580exii, MT-24ex, Godox AD300Pro
Triggers:- x5 PW TT5s & x2 PW TT1s & x3 Godox X-Pro
You forgot to mention an extension cable.
