11-27-2024
03:58 PM
04:00 PM
Hello, I have a 270EX II. With brand new batteries I turn it on and the ‘flash ready’ indicator never turns green, continuously red and it will not test fire or fire on my camera.
any suggestions?
11-27-2024 04:18 PM
What camera do you use. If its an EOS DSLR the depth of field preview button can be pressed and the speedlite will produce modeling flash.
11-28-2024 09:24 PM - edited 11-28-2024 09:24 PM
The flash should charge whether on or off a camera. Are you using alkaline or lithium batteries, not zinc-carbon cells?
If so, and it never indicates full charge, the flash is suspect. This model was introduced in 2011. May be failing.
11-28-2024 09:40 PM
When the flash is fully charged it will be red not green. Green means quick flash which means it hasn’t fully recharged yet.
11-28-2024 09:44 PM
Probably has a capacitor, it may have failed or a the unit itself has wiring issue.
This is a good option for replacement. I picked one up this year.
https://www.usa.canon.com/shop/p/refurbished-speedlite-430ex-iii-rt
