Speedlite 270EX II "Flash ready" indicator never turns green
iwillrescueu
Hello, I have a 270EX II. With brand new batteries I turn it on and the ‘flash ready’ indicator never turns green, continuously red and it will not test fire or fire on my camera.
any suggestions?
4 REPLIES 4
deebatman316
What camera do you use. If its an EOS DSLR the depth of field preview button can be pressed and the speedlite will produce modeling flash.
-Demetrius
Bodies: EOS 40D & EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 50mm F/1.8 STM, EF 70-210mm F/4 & EF 85mm F/1.8 USM
normadel
The flash should charge whether on or off a camera. Are you using alkaline or lithium batteries, not zinc-carbon cells?
If so, and it never indicates full charge, the flash is suspect. This model was introduced in 2011. May be failing.
When the flash is fully charged it will be red not green. Green means quick flash which means it hasn’t fully recharged yet.
-Demetrius
Probably has a capacitor, it may have failed or a the unit itself has wiring issue.
This is a good option for replacement.  I picked one up this year.
https://www.usa.canon.com/shop/p/refurbished-speedlite-430ex-iii-rt
