03-15-2016 03:34 AM
Hi all,
I have an 430EX II which emits a very weak flash when test fire. It does not emit a high pitch sound when turn on indicating that it is charging the capacitor (only a constant low buzzing sound).
Can someone confirm that it is the flash capacitor that is faulty and not the flash bulb or firing circuitry?
Thanks.
03-15-2016 08:33 AM
@Wild-bear wrote:Hi all,
Thanks.
Newer flashes like the 430EX II do not emit a high pitch sound when charging, they are completely quite. The only sound my 430EX II flash makes is when the zoom in the flash head changes focal length.
03-15-2016 09:47 AM
What happens when you actually use it?
03-15-2016 09:52 AM
Same thing. It fired a weak flash. I took measurement and the photo flash capacitor had very little voltage. I think the inverter circuit is faulty and does not upconvert the voltage to the correct high voltage.
03-15-2016 09:55 AM
I took the assembly apart and did not see any obvious burn mark.
Now a I have a small black piece of plastic ~2cm long and a round white rubber seal which I don't know where they should go as they fell out when I opened the casing.
PS, I'm quite competent with electronics 🙂
03-15-2016 09:57 AM
Then you are on your own. Sounds like it is time for a new flash.
