05-31-2024
04:20 PM
04:57 PM
Tiffany
So I purchased godox mf12 twin flashes ,with godox xpro 2 transmitter . There were conflicting reports regarding HSS on mf12, xpro2 supports hss. I contacted Godox directly and they confirmed that they don’t support hss. However if I enable hss on xpro2 I can easily set high shutter speed and flashes are firing, does it mean they are not synced or is hss actually working?
05-31-2024 04:45 PM
This forum is neither Canon Service or Canon Support. This is a social media forum targeting Canon gear. Advice for Godox gear may be very limited
If Godox says it does not work, then it does not work. If you get the results that you need, then I would guess that it may work to some degree, perhaps in some type of degraded mode. ???
05-31-2024 04:45 PM
06-01-2024 03:20 AM
No, you are right I came here as to general forum . I forgot that. Sorry.
