550EX and 100-400 lens
mitchmcc
Enthusiast
I have an older 550EX that I used to use with my 600mm.   I have a Really Right Stuff flash arm and a camera body plate that I used, along with a Canon Off-camera shoe cord.
I have since moved toward using my 80D body with the 100-400 IS ii lens.   Do most people simply use the flash on the camera body flash mount, or is there any way to get the flash higher off the camera, which is what most people recommend?
I have looked at all of my pieces mentioned above, and cannot see how they can be used with the 80D and 100-400...
If people have success shooting birds with the flash mounted on the camera body, then I will give it a try.
Any and all comments welcome!
6 REPLIES 6
rs-eos
I did first start with an off-camera shoe cord.  But personally found it too limiting for what I wanted to do.
Now, I only ever use off-camera flash without any cables.  I have numerous light-stands.  Both lightweight stacking-style Manfrotto stands and heavier-duty C-stands.  Then, modifiers to shape/direct the light.
Having said that, all my subjects are fairly close.   And when outdoor (and attempting to "compete with the sun"), you really need to either have the light source very close to your subject, or gang-up your speedlites.   I have a Lightware Direct Foursquare bracket so I can mount four 600-series speedlites to a single modifier.  Even when all of them are all full power, that light source still needs to be fairly close to my subject.
Example (using sunny 16).   I want to overpower the sun by say 1 full stop.  So, I need light output of f/22.   Say my aperture is f/2.8.  (Side note: I'm going to ignore the power loss in using high-speed-sync for the purposes of this paragraph).  With a single bare 600 EX speedlite, to get f/22, I'd need to run that at full power and be around 8 feet from my subject.  Problem is that if want a softer/larger light source, I'll use a modifier that will eat up say arround 2 stops of light.  Hence my using four speedlites together (which gives me now that 2 stops back).
Since your subjects are birds, I don't think flash is going to do you much good at all due to the distance they'd be at from your light source.
Ricky
Thanks for the quick reply! Well, at least using the old setup, there are very many professional photographers that use this type of setup (I learned about it from Art Morris) who, along with a Better Beamer flash extender, for fill flash for bird photography. Flash is never perfect in this situation, and I have not used it this way very often. Still, I had dug out the old Speedlite and wondered if anyone used it for birds on the camera body mount.
Wanting the flash on your camera though means the light source is now the same distance from your subject as the camera itself.  I just don't think the math will support want you want to do.
If I did the math correctly, for a fill flash say 2 stops under the ambient (sun), you'd need to be 32 feet away from your subject and run the flash at full power.   This is with f/5.6.
How far away are you from the birds?
Ricky
With wild bird photography, you can be pretty far away, and sometimes the birds (warblers) that you want are very small. This is why with my 600mm f4 lens I almost always use the 1.4 tele-extender as well, and end up shooting at f5.6. With plenty of light, I get good shots (www.excellentbirds.com), but I would say 100% of those were not shot with flash.
Also, to get the extra reach, I have even used the 1.4 TC on the 100-400, which yields f8. By using a faster ISO than I did in the old setup, I can still get good photos. But if I am going to shoot in the rain forest in Costa Rica, that will not work without flash sometimes.
Look into the better beamer.
As I mentioned above I do use the Better Beamer
