07-14-2026 02:37 PM
Watched a couple of Stewarts videos and had a quick go in the garden with 100mm attached.
Quite pleased for starters. Now need to learn more about stacking.
Ramsden
07-14-2026 05:13 PM
Now we're cookin!
What were your settings on this image.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
07-14-2026 05:48 PM
Woahhhh
07-15-2026 02:40 AM
Im finding the wind to be tricky at such close quarters. But very pleased with this start.
07-15-2026 08:05 AM
Yes wind can kill a good day. If light is good a higher shutter speed will sometimes work if the subject stays in frame.
That's a good grab Ramsden considering you just got started with Macro.
Personal Gallery
07-15-2026 08:27 AM
Good photo. When I was a kid, the wind would carry those seedlings forever. We called them Santa Claus; catch them and release them. Didn't take a lot of entertain us in those days.
07-15-2026 08:45 AM
Thanks guys
Really appreciate your support.
I started playing around with focus bracketing last night. I like the concept, but find it a touch scary. Just for starters, what sort of numbers are you crunching on this operation. I started with 10 shots at 3 increments. That produced a noticeable difference, and Ive yet to get them stacked in dpp.
Really enjoying this
Best
Ramsden
07-15-2026 09:04 AM
The increments will depend on what you want to end up with in your image. I lower increment and more shots will give you sharpness across the majority of the image. Wider increments and DOF will play a roll in the shots in between those increments.
This example was shot at an increment of 1 with 30 frames, I focused on a blade of grass in front of the mushrooms and shot to the back blade of grass. I reviewed the frames and deleted the ones on the back where I wanted to transition to start my DOF. I stacked the images in PS that weren't discarded. Stacking allows you to present the image sharpness as deep into the image as you desire. I always shoot more than I think will be in my stack, can't use what you don't have to create the finished product. I believe I used 17 of the 30 shots and the ones not used were all on the back end.
Personal Gallery
07-15-2026 09:29 AM
Thanks Marc
That’s really helpful and a lovely example. Focussing on a blade of grass sounds very challenging. I’m currently set up in my back garden and even the slightest wind causes havoc with the focus. Do you switch to servo when its windy, or perhaps just increase the shutter speed?
Thanks for your help
Ramsden
07-15-2026 09:43 AM - edited 07-15-2026 09:46 AM
Honestly I give up when it's windy as it just becomes to frustrating. For the mushrooms it was dead calm so focusing on the grass shooting @ f5.6 was no problem. The shutter speed was 1/2500 sec.
Today is a perfect example for me in Chicago, I wanted to get out and test a new flash I picked up, the Godox MF-T76 C. I woke up early, no wind and set up the gear, opened the garage door and it was blowing. Changing the settings rarely helps me but you may have better results.
Find some subjects out of the wind, something a bit more stationary for now. Once you find you are getting things down pat you can hold a branch or leave to hold it still and shoot with the other hand. Subjects closer to the ground or on solid backgrounds like trees are easier on a windy day, the wind has less impact. For me getting down there is easy but getting my old butt up is where the trouble starts. I look like a turtle that's rolled over on its back. 😄
Personal Gallery
