Chickadee
johnrmoyer
Whiz
Whiz
I often see comments that it is better to crop than use an extender. I disagree and think that the Canon extenders together with the digital lens optimizer in Canon DPP software work very well. I hope this example will be helpful to some.
The advantage from using the extender is more pixels on the bird.
The disadvantages from using the extender include lower contrast at edges in the image and a smaller aperture which requires higher ISO.
I use the Canon DPP digital lens optimizer to remove small aperture diffraction blur. The capture sharpening (Richardson/Lucy deconvolution) in rawtherapee free software also works well. The DPRAW tool or the "clarity" setting in DPP can correct some of the loss of contrast at edges. I use exiftool free software to add IPTC metadata, but for some cameras it can be added using the Canon EOS Utility software.
I have published this photo at https://www.rsok.com/~jrm/2025Jan15_birds_and_cats/2024dec22_chickadee_IMG_2390c.html , https://1-john-moyer.pixels.com/featured/chickadee-2390-john-moyer.html , https://licensing.pixels.com/featured/chickadee-2390-john-moyer.html , https://okla.social/@johnmoyer/113912003640868920 , https://bsky.app/profile/jrm.rsok.com/post/3lgv525qvbk2thttps://www.facebook.com/JohnMoyerPhotography/posts/pfbid0DLcPHMLYx2rC3p4je3zTNNo4wV49G3rsbwCZQuBQeT... , and archived at  https://web.archive.org/web/20250115185048/https://www.rsok.com/~jrm/2025Jan15_birds_and_cats/2024de...
Carolina Chickadee (Poecile carolinensis) on oak twigs Norman, Oklahoma, United States on December 22, 2024 ; EOS R5 ; EF100-400mm f/4.5-5.6L IS II USM +2x III ; 800 mm ; 1/500 second ; F/13 ; distance from camera to bird about 8.5 metersCarolina Chickadee (Poecile carolinensis) on oak twigs Norman, Oklahoma, United States on December 22, 2024 ; EOS R5 ; EF100-400mm f/4.5-5.6L IS II USM +2x III ; 800 mm ; 1/500 second ; F/13 ; distance from camera to bird about 8.5 meters
I used Canon DPP to process the CR3 raw file. I save the edits as a recipe in a dr4 file. Exiftool can read the dr4 file so that I have a record of the edits. I have placed camera settings and all edits in the table below. I used graphicsmagick free software to place a frame around the image with a caption in the frame.
ExifTool Version Number 13.09
Camera Model Name Canon EOS R5
Software Digital Photo Professional
Modify Date 2024:12:22 14:15:29
Exposure Time 1/500
F Number 13.0
ISO 500
Date/Time Original 2024:12:22 14:15:29
Offset Time Original -06:00
Continuous Drive Continuous, Low
Focus Mode AI Servo AF
Record Mode CR3+JPEG
Metering Mode Evaluative
Focus Continuous Single
Image Stabilization On (2)
Camera Temperature 29 C
Measured EV 14.12
Measured EV 2 30
Canon Firmware Version Firmware Version 2.1.0
Shutter Count 22497
Valid AF Points 1
Image Unique ID 52a5703634444a4ba1b91d62c962c613
Time Zone -06:00
Time Zone City Chicago
Daylight Savings Off
Battery Type LP-E6NH
Focus Distance Upper 9.07 m
Focus Distance Lower 7.89 m
Shutter Mode Electronic First Curtain
Add IPTC Information Enable
Measured RGGB 524 1024 1024 623
WB RGGB Levels As Shot 1964 1024 1024 1820
Color Temp As Shot 5357
Per Channel Black Level 2047 2047 2048 2047
Normal White Level 13535
Specular White Level 14888
Linearity Upper Margin 12735
Picture Style User Def Standard; Standard; Standard
Picture Style PC None; Standard; None
Vignetting Corr Version 96
Peripheral Lighting Setting Off
Chromatic Aberration Setting On
Distortion Correction Setting Off
Digital Lens Optimizer Setting On
Peripheral Illumination Corr On
Auto Lighting Optimizer Off
Highlight Tone Priority Off
Long Exposure Noise Reduction Off
High ISO Noise Reduction Off
Digital Lens Optimizer Standard
AF Config Tool Case 1
AF Tracking Sensitivity 0
AF Accel/Decel Tracking 0
AF Point Switching -1
AI Servo First Image Equal Priority
AI Servo Second Image Equal Priority
One Shot AF Release Focus Priority
Auto AF Point Sel EOS iTR AF Enable
Lens Drive When AF Impossible Continue Focus Search
AF Point Display During Focus Selected (constant)
Initial AF Point In Servo Manual AF Point
Subject To Detect Animals
Eye Detection On
Roll Angle 0.2
Pitch Angle 19
Focal Length 800 mm
Exposure Mode Auto
Scene Capture Type Standard
Lens Model EF100-400mm f/4.5-5.6L IS II USM +2x III
Keywords chickadee, Carolina Chickadee, Poecile carolinensis, bird, wildlife, wildlife photography, Oklahoma
Location Shown Country Name United States
Location Shown Province State Oklahoma
Description Carolina Chickadee (Poecile carolinensis) on wild grape vine in Norman, Oklahoma, United States on December 22, 2024
Rights https://www.rsok.com/copyright.html , Copyright John Moyer, all rights reserved
File Name IMG_2390.dr4
White Balance Adj Daylight
WB Adj Color Temp 5200
Color Saturation Adj 1
Unsharp Mask Strength 1.7
Unsharp Mask Fineness 1.6
Unsharp Mask Threshold 4
Shadow Adj 0
Highlight Adj 0
Luminance Noise Reduction 1
Chrominance Noise Reduction 1
DLO Setting 70
DLO On Yes
DPRAW Microadjust Back Front 1
DPRAW Microadjust Strength 8
Crop X 1377
Crop Y 1546
Crop Width 4800
Crop Height 3200
Crop Rotation 0
Crop Angle 0
Crop Original Width 8192
Crop Original Height 5464
0 REPLIES 0
Friends and Family
