01-09-2024
01:22 PM
01:29 PM
when recording, I use XLR inputs 1&2.
The audio is one channel when I download file to edit software. Can I split the channels in the video, and have the ability to manage each seperately?
01-10-2024 04:44 AM
See the manual page 74, "Setting the XLR Terminal". Do you have the "CH1" option set to "CH1/CH2"? If so, that's your problem.
Normally you should set this to "CH1 -> CH1"; then each XLR input is recorded to a separate audio channel (left and right), and you can split them or treat them separately in post.
01-10-2024 10:40 AM
Thank you. The file has both channels together with the video. I will have to see if I can split the audio.
Will check back.
