CF Corruption. Management File Error.
conloff
After having a look at footage on my laptop, in Premiere Pro. I put the 128gb Sandisk CF Card back into the C300 mk2 and it showed up on the screen: Management File Error. The same happens in media mode. Ive tried recovery softwares but after it says its successfully recovered them, I try to import them into Premiere Pro, or use them in the camera and I get the same message.
Anybody experienced this? I am desperate...
3 REPLIES 3
Not much you can do.  Try one or more data recovery utilities.  PhotoRec or similar.  SanDisk recommends Recure Pro
https://www.cgsecurity.org/wiki/PhotoRec
https://kb.sandisk.com/app/answers/detail/a_id/4985/~/data-recovery-for-memory-cards-and-flash-drive...
This happens.  Can be failure of the card, improper formatting or the slot itself.
Have you tried VLC? It can see/play files that others can't.
Sounds like it may be a case of the recovered files may have been renamed.
chaseoki
I believe you have to format the card in camera always before using it again. Sorry about the footage loss.
