C500 markii CRM files on mac OS Ventura 13.0.
joaquinbacaasay
Trying to edit CRM files on Final Cut 10.6.5 with macOS Ventura 13.0.  Doesn't seem to be a Canon plug in for that yet.  Does anybody have a workaround?  Even to view footage?  I did try to install the last plug in for the previous OS, but didn't function.
thanks
j
3 REPLIES 3
GeanWaiter
Hi! try to do it in Handbrake
rs-eos
Which codec are you using to capture your footage?  When I visit the Canon Support Page for the C500 Mark II, I see plugins for working with RAW in Final Cut as well as Canon's XF Utility, amongst other things.
I did though have to change the dropdown on that support page to an older OS version for the list to be populated.
Ricky
RagenVox
One workaround you can try is to convert your CRM files to a compatible format using a video converter tool.
There are many video converter tools available online that you can use to convert your CRM files to a format that Final Cut can recognize. If it is just a software issue, try a project management online tool. I personally use this one. I hope that helps, and good luck with your editing!
