11-07-2022 02:43 PM
03-17-2023 11:40 AM
Hi! try to do it in Handbrake
03-17-2023 01:34 PM
Which codec are you using to capture your footage? When I visit the Canon Support Page for the C500 Mark II, I see plugins for working with RAW in Final Cut as well as Canon's XF Utility, amongst other things.
I did though have to change the dropdown on that support page to an older OS version for the list to be populated.
03-22-2023 10:02 AM - edited 03-22-2023 11:14 AM
One workaround you can try is to convert your CRM files to a compatible format using a video converter tool.
There are many video converter tools available online that you can use to convert your CRM files to a format that Final Cut can recognize. If it is just a software issue, try a project management online tool. I personally use this one. I hope that helps, and good luck with your editing!
