03-29-2014 07:55 AM
I have Pixma PRO-100. It works OK but if I disconnect the USB cable it reports off-line. I have reloaded the driver as Network connected? Tests run OK, USB connected. WiFi blue lamp lit. Home 4-channel network connectin Laptop and Tablet. Also the tablet cannot find printter.
Laptop HP Pavilion g6, Win 7, 64 bit. Tablet, Samsung Galaxy Note 10.1. Android 4.3.
Thanks.
04-04-2014 03:11 AM
Have you installed the printer software on the laptop?
The Andriod is going to need an app. Click here.
04-09-2014 02:34 PM
check to make sure the IP address that's configured for the printer port, and the actual printer are the same. For example, on the printer driver properties, look at the port tab. Open a web browser on your PC and enter that IP address in the address box, does it bring up the web interface for the printer?
04-10-2014 09:27 AM
A liitle confused.
Are you trying to print directly from the "Laptop HP Pavilion g6, Win 7, 64 bit."
And "AIR" print from the "Tablet, Samsung Galaxy Note 10.1. Android 4.3."
There is no wi-fi router involved?
04-14-2014 03:43 PM
