Canon iPF6100 large format printer; hardware failure 2F26
Jody_surfs
Hi!
I recently acquired a used Canon iPF6100 large format printer for free. The previous owner said it hadn't been used in a year but that it was working before. When I first started the printer, it would basically get through its boot sequence and then immediately display "hardware failure 2F26".
After some research, I believe the fault is due to "If the motor could not be run at all or has resulted in an error after moving by a slight distance: A. A mechanical load error may be suspected." I bought some fine mechanical lubricant and lubed the drive shaft. Now the carriage moves a small amount at start up but still gives this error.
Does anyone have experience or ideas on what else I can do to repair?
Thank you!
0 REPLIES 0
