05-06-2022 03:38 PM
Hello,
We have an IR-ADV 525 III that defaults to duplex scanning from the feeder on top. I'm looked through the manual and options/settings but there doesn't seem to be any way to disable duplex scanning. Am I missing something?
Thanks!
05-07-2022 08:35 AM
Hi, mandrichtech!
Thanks for posting! While our forum community members are welcome to chime in, Canon does not provide direct support for imageRUNNER series products. Instead, your dealer will be able to help you! If you don't have a dealer and you're in the United States, please call us at 1-800-OK-CANON (1-800-652-2666) and we will be happy to provide you with the names of dealers in your area.
If you're outside the USA, visit http://global.canon and choose your country or region from the map for local support.
We hope this helps!
05-09-2022 10:08 AM
Hey there,
you just set simplex in the send function and then click on the canon logo, in the upper right corner of the lcd. Then select "change default settings" and save it. Then you should have set it as new standard for sending documents.
Cheers
Daniel
