scangear not responding
aryehis1
I have a Pixma MX490 printer/scanner and when I run scangear it just hangs (picture scan and document scan). I last used it a couple of weeks ago without a problem.
I tried downloading the latest from Canon but it didn't help.
Also tried running as administrator but no luck.
1 REPLY 1
Greetings ,
Are you running the new installer over the existing installation?
I suggest you remove the existing installation, restart your computer, then run the updated installer.
Let us know if that helps.
