05-08-2025
02:28 AM
09:15 AM
Hello,
I have old PC of windows 10, and where printing & scanning is done via MF toolbox 4.9.
I bought windows 11 PC and installed the same driver & tool box, so i can print via network, but issue in scanning. I also download new software & drivers from CANON's website and still have issue.
I got error this error when i push the SCAN button from printer:" MF TOOLBOX THAT IS SUPPORTED BY THE SCANNER YOU ARE USING MAY NOT BE INSTALLED IN YOUR COMPUTER. INSTALL THE APPROPRIATE MF TOOLBOX AND THEN PERFORM THE OPERATION AGIAN."
I opened the MF tool box- scan function > click on scan-1 button > i got the error that "THERE IS NO SCANNER SELECTED. PLEASE SELECT THE SCANNER". So i go to setting and select the CANON MF 4700 SERIES as a scanner and pressed OK. then go to SCAN-1 button and got the error: "CANNOT COMMUNICATE WITH SCANNER. CABLE MAYBE DISCONNECTED , OR SCANNER MAY BE TURNED OFF. CHECK THE SCANNER STATUS AND TRY AGAIN. SCANNER DRIVER WILL BE TERMINATED."
I installed both the driver via Cable & via Network. I cannot scan via cable or via the Netwrok.
I hope i can get my scanner back.
05-13-2025 10:21 AM
Thanks for joining the conversation, BHAVINDONGA96! We appreciate the info, though we need to let you know that the imageCLASS MF4720w is not supported by our team here at Canon USA since that product isn't available in this country. If you live outside the United States, please click HERE and select your country to find support in your part of the world. Your fellow Community members are still welcome to offer their advice.
Thanks for choosing Canon!
