05-12-2016 10:47 AM
i am runing windows 10
05-13-2016 05:32 AM
You need to provide additional information about your issue. Provide enough information so that someone may try to reproduce your scenario, in order to better understand your problem, and hopefully provide you with a solution.
What is the model number of the device that is giving you the message? What is the Operating System that you are using? Are you trying to connect wirelessly, or via a cable of some type? Did it ever work, or is this new device? Please, try to help someone to help you. Try to describe your equipment, connections, and the steps required to reproduce the message.
