Wireless printing to a Pixma MG3100
gordon99
My Pixma MG3100 printer is usb connected to my wife's Windows 7 PC and she is able to print at normal speed. I have a laptop on which I have installed a Xubuntu OS. Both the PC and laptop are on Windows Homegroup.
When I print from the laptop through the Homegroup however, by wireless connection, a 13 kb document that takes just 10 seconds to print from the PC takes 60 seconds from the laptop.
In order to try to speed things up I would like to print directly from the laptop via the printers wireless connection while leaving the usb connection to the PC. If this is possible would someone kindly explain what I have to do to achieve this. I do have the Canon printer set-up disk if this is needed. I do not want to interfere with the PC to printer usb connection in case it degrades the printing performance. My wife would not be pleased.
Thank you merrymary for your speedy reply, even if it was not what I wanted to see.
2 REPLIES 2
merrymary247
Rising Star
There isn't a driver that supports Linux, only Mac and Windows, so the only way you can print is through the homegroup/your wife's PC.
