Want to undo "Using Only Printer"
b-b
I have a new Pixma TR7520 printer. A wireless printer is new for me. Anyway, when setting up I made a mistake in "Preparing for Connection." I pressed Stop as if i wanted to "use only printer." And then, "Do Not Connect." How do I undo such a basic choice??
2 REPLIES 2
I don't believe I've ever seen the messages you reference above.  Maybe this is a difference in terminology?
Is this on PC or MAC?  (Which OS)
Is this a dialog that appeared when you were running the software installation?
Did the device install or not?
Are you having a problem printing?
If yes, I would suggest reinstalling the software.
If not, you are probably ok.
Hello shadowsports,
Thank you for your prompt reply! As you suspected it would, my problem has ironed out, especially with me using the online manual closely (ah-HAH). For the record I have a Windows 10 machine.
b-b
