WIFI 5Ghz
tjisret
Just bought the Canon MG6620 and I have connected it to my Home Network with out a problem and she is working great!  But it connected to the 2.4Ghz Band of my router. But I was just wondering does this printer support the 5Ghz Band which I would much rather connect to?
Ramona
Hi tjisret,
The PIXMA MG6620 is not compatible with the 5Ghz band of routers.
16 REPLIES 16
Ramona
Hi tjisret,
What Canon printer does support 5 GHz? In my environment 2.4 GHz is too crowded and I moved my whole WLAN to 5GHz.
Hello.
Our printers are not able to connect to 5.0GHz networks.  If you have a printer that has an Ethernet connection, consider using this connection instead.  Devices that connect to the same router should be able to access the printer this way.
If additional assistance is needed with this matter, find more help at Contact Us.
tinyteri
What about a wireless network USB dongle?
tinyteri
Linksys Wireless-AC USB Adapter (Manufacturer Refurbished)
Upgrade Wireless Speeds
Plugs into laptops and desktop PCs
Provides faster Wireless-AC speeds
Supports transfer speeds of up to 433MBps
Dual-Band Connectivity
Compatible with 2.4GHz and 5GHz bands
Helps prevent interference
433MBps on 5GHz band, 150MBps on 2.4GHz
tinyteri,
A standard Wi-Fi router will be needed in order to access the printer wirelessly over a network.  If one is not available, the printer will have to be connected to your computer via USB cable.
tinyteri
If i get a dual band wireless repeater can I use the Ethernet port on it to make it work? Mines a mx470
tinyteri
No port..lol..I set a duel wireless repeater up..I now print with a5 GHz computer on a2.4 GHz printer 😁
tinyteri
