Printer, Wifi, New Modem, wont work
limperia
I have a PIMA MX922 printer. I just updated my modem and router and now I cant print via wifi on amy of my decices
2 REPLIES 2
Patrick
Hi limperia,
When you change your modem/router, your new netowrk information must be entered on your PIXMA MX922 in order to use it wirelessly again.
To do this, please follow these steps:
 1.  Turn your PIXMA MX922 on.
 2.  Press the MENU button on your PIXMA MX922.
 3.  Use the arrow buttons to select WLAN Setup and press OK.
 4.  Press the STOP button (to select Other setup options).
 5.  Select Standard setup and press OK.
 6.  Select Other setup and press OK.
 7.  Select Advanced setup and press OK.
 8.  Select your wireless network name from the list that appears and press OK.
 9.  Select the security setting that your wireless network uses and press OK.
10.  Press OK to access the on screen keyboard and enter in your wireless network password.  Please note that this password is case sensitive and if it is entered incorrectly, your PIXMA MX922 will not connect to your network.  To switch between upper case letters, lower case letters and special characters, please use the middle function button below the LCD of your PIXMA MX922.
11.  Press the left function button under the word "Done" once the password is entered.
You will be able to use your PIXMA MX922 wirelessly again once complete.
Thanks
It worked!
Friends and Family
