11-18-2014 06:30 PM - edited 11-18-2014 06:31 PM
Hi and thanks for any help,
Equipment:
Printer: Pixma MG6200
Router: Linksys ea 6700
OS: Windows 7
2+ year owner of this printer and I have had to reinstall on numerous occassions in past with no problems.
Now, I can not print via wireless. Windows stated that it is off line via the windows diagnostic trouble shoot. So I uninstalled and reinstalled via USB. I utilized the WPS router feature to connect printer to router with no apparent difficulty. However, when I go to complete the installation the printer is not discovered. I double checked that network discovery is enabled. I can use printer via wired.
The network configuration page is as follows:
(Wireless Lan: Enable)
Link Status : Active
MAC address : 2C:9E:FC:19:B9:7D
SSID : Linksys 11358
Connection Mode : Infrastructure
Channel : 5
Encryption : AES
WEP Key Length : Inactive
Authentication : WPA2-PSK
Signal Strength : 100%
TCP/IP Version : IPv4
IP Address : 192.168.1.115
Default Gateway : 192.168.1.1
Subnet Mask : 255.255.255.0
Subnet Prefix :
IPsec :
Security Protocol :
Wired (LAN) : Disable
Link Status : Inactive
Mac Address : 2C:9E:FC:07:FE:1E
IP address :
Default Gateway :
Subnet Mask :
Subnet Prefix Length :
IPSec :
Security Protocol :
(Other Settings)
Printer Name : 19B97D000000
Shared Memory Card : Enable
WSD : Enable
WSD Timeout : 1 (min)
LPR Protocol : Enable
Bonjour : Enable
Bonjour Service Name : Canon MG6200 series
DNS server : Auto
Primary server :192.168.1.1
Secondary server :
Proxy server : Disable
Proxy Port :
Proxy Address:
IP Address Filtering : Disable
Any help will be greatly appreciated.
Thanks
12-02-2014 08:59 AM - edited 12-02-2014 09:01 AM
We had a 2hour power outage yesterday. Today one of our 3 computers would not print, though connecting to the internet OK. Just as your own diagnosis, so was ours.
We tried many of the solutions here, but the really only simple way was to delete the Mx6250 printer from the Acer Ferrari 1 and re-install the drivers from Canon.
