PIXMA TS9521Ca doesn't ask for password and Wi-Fi connection fails
lnitahara1
I'm trying to set up a TS9521Ca and connect it to WIFI.   The problem is that I am never prompted by the printer to enter a password so the connection fails.  Did anyone else have to deal with this?   I called support and they just wanted lots of money.  Thank you for any assistance.
2 REPLIES 2
jimyamo
We're also having this issue. I wasn't able to find any solutions to this online. Any ideas?
Let me address the original post and your question too 🙂
Canon will occasionally charge a nominal $20 fee to support a product out of warranty.  Payments for such are done through your MyCanon account.  Support agents will not ask you for a credit card and if they do you are not speaking to Canon.  Many people get scammed each year because they think they called Canon, but in fact they contacted a scammer or third party.  Be sure to protect yourself from this.
To see your support options for a Canon product, log into your MyCanon account and register the device.  You will then be provided with support options.
MyCanon
https://myprofile.americas.canon.com/us/signin
Telephone number for Canon support
1-800-652-2666
The TS9521Ca requires a 2.4 GHz wireless broadcast that supports WPA2 encryption.  It will not connect to a 5 GHz or other broadcast, or one that uses WPA3 encryption.  Please ensure your network meets these requirements.
Hints:
If you have a dual or tri-band router and all broadcasts are using the same SSID name, you can give each broadcast a unique name or temporarily disable the bands that the printer is not able to connect to until a connection is made, then re-enable them.
If you're having difficulty making a connection using the printer's control panel, You can use the printer's Wi-Fi connection assistant software or just rerun the printers setup utility which will allow you to choose a network and set a new password. Both downloads are available on the printers support portal.
Canon Support for PIXMA TS9521Ca | Canon U.S.A., Inc. https://share.google/A38s9HsrtskzemoCa
