05-10-2019
11:28 AM
10:41 AM
I have a new mac laptop (first mac). My printer/scanner is a Canon MX452. The printer shows up in my list of printers in System Preferences "Printer & Scanners" and I can print from my Mac to the printer. I've got the printer set up and working. However, the same device is also a scanner, but it does not list itself as one there and gives no scan option.
I downloaded the scan driver from the Canon website, and I have "Canon IJ Scan Utility" in my applications. I can open that, but when I try to scan it says Scanner is turned off or USB cable is disconnected. My scanner is on, but I don't have the computer attached to it with a cable. I want to wirelessly scan (just like I can print).
On my scanner when I try to go to settings to detect this Mac it does not see it and offer it as an option.
Is there a way I can get the wireless scanning set up? Any ideas? Or must I hook up with a cable (which I would have to buy an adaptor for etc.)?
(FYI the wireless scanning does work for my PC.)
05-11-2019 04:57 AM
Hi katshe77,
To troubleshoot the scanning issues on your Mac, please perform the followingt troubleshooting steps:
If Image Capture listed the MX450 in the upper left corner, perform the following steps:
If Image Capture does not list the MX450 in the upper left corner, perform the following steps:
There is an additional driver that can be downloaded from the Canon website that will assist with the communication between the scanner and the computer.
05-11-2019 04:57 AM
Hi katshe77,
11-22-2019 01:54 PM
Where is the Mac program "Image Capture"? Is it under Applications?
11-22-2019 06:35 PM
I can print wirelessly from my Mac, but my Pixma MX522 scanner doesn't work since I downloaded Catalina. I downloaded the software Canon IJNetwork Tool 4.7.2 and Quick Menu 2.8 with no effect. Where to go, what to do? Thanks.
12-28-2019 12:17 PM
I called Support at Canon and was told that the 522 Pixma scanner is not compatible with the Catalina iOS. He suggested that I use Apple's Image Capture instead.
12-28-2019 11:52 AM
I tried those instructions for my MF4450. I have downloaded the new driver. I receive this message:
The operation couldn't be completed (com.apple.imagecapture error
5294957375.) (-9921)
03-31-2020 07:27 AM
Scanner shows connected until I attempt to scan to Mac.
It shows me the printer and tells me to scan and then the scan gives an error saying not able to connect.
Once i restart the printer it shows connected but the scan button is greyed out.
04-19-2020 11:44 PM
04-20-2020 02:26 AM
What posting were you referring to when you said the solution is right here? Sould you provide a link to the downloadable driver? Thanks.
06-13-2020 09:58 AM
I just purchased a Canon Pixma G7020 and have set it up wirelessly. I have been able to print from my computer but not scan. I downloaded the Scanner Utility and tried to set it up. It's not recognizing the scanner. I get the same message as mentioned in earlier posts.
I tried the Image Capture solution mentioned in a previous post, and Image Capture sees the scanner but the Canon Scanner Utility does not.
I tried to scan directly from the printer/scanner itself, using the panel, but that requires saving a scanned image to the computer. Since the machine doesn't work wirelessly, the only save option requires me to connect the machine via a USB cable rather than wirelessly.
Needless to say this is frustrating! Part of why I bought this printer was that I read that many things could be done using web-based software rather than the hard-to-read panel. But if the software doesn't work, that the option is not viable.
Has anyone come up with a solution to this problem? Did Canon support offer any solutions?
Thanks
