How to enter Wi-Fi password with numbers on printer
vickybuffington
Can't get the password to work when I get to having to put in the numbers, the screen on printer doesn't show the numbers.  It shows the letters, but not the numbers so I can't get in our passcode/password to get the printer connected to our wifi
@vickybuffington,
You can toggle between letters, numbers and symbols by tapping the # key if I remember correctly.
2 REPLIES 2
Tiffany
Moderator
Moderator
Welcome to the forum!
So that the Community can help you better, let us know what model printer. Also, which version of Windows or macOS you are using? How are you connecting? Is there an exact error message?
Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
@vickybuffington,
