05-05-2019 10:05 PM
Hello!
So, I have this kind of older camera, the Cannon PowerShot A590IS, and I went to use it the other day, and it said the memory card was full. Well I don't mind, I went out and got a new one, but I put it in and now the camera says "Memory Card Error" at the top, and I'm assuming that is why I can't take pictures. Any advice? I need some help here LOL!
05-06-2019 09:45 AM - edited 05-06-2019 09:48 AM
A590IS
Will the camera read whats on the old card in playback mode? Is the card indeed full?
If possible, can you connect the camera to a computer and copy data from the card?
~CarePaks Are Worth It
05-06-2019 04:03 PM - edited 05-06-2019 04:04 PM
@shadowsports wrote:A590IS
No, I cannot see what is on the card on the camera or on the computer so I don't know if it's actually full. 😕
05-06-2019 09:51 AM
Hi jalynnjohnsonnn!
Bear in mind that the A590 is an older camera, so it's only compatible with SD and SDHC cards. That means you want to use full size (not mini/micro) SD cards that are 32GB or smaller. If your card is larger than 32GB, the PowerShot A590 IS will not be able to read the camera. Also, if you're using a mini/micro SD card inside an adapter, the camera may have difficulties.
I hope this helps!
