08-12-2020 05:01 AM
Hello, I have the G7X Mark III with firmware version 1.2.0 and in Video mode, with high framerate mode I see only HD 100.0P
Shouldn't it be 120 fps?
SHOOT1
Movie rec quality 1290x1080 100.0 fps
Standard (IPB)
Max rec time 00:07:29
High framerate disabled gives me
4K 25.00P FHD 25.00P
FHD 50p HD 50P
It's really hard to google for this issue since all I get is data sheets and reviews. Can somebody push me into the right direction, because I must do something wrong here. I also just got the camera, so I assume it is a user problem 😄
Thank you in advance!
08-12-2020 02:45 PM
08-12-2020 02:45 PM
Sounds like you are in PAL mode. Can you switch it to NTSC?
08-13-2020 04:24 AM
You were right. I would have never guessed. Wow.
Thanks!
