"memory card error" on brand new G5X
Boejakasja
I bought a new Powershot G5X, inserted a 128GB sd card (also brand new) and the camera says "memory card error"
It is a cheap 20€ 128GB sd card from Transcend - Transcend Ts128Gsdc300S Sdxc Memorycard, I, C10, U3, V30, Black, 128Gb
Its this SD card
When i put in a very old 8GB SDHC card, the camera works fine, so i think the cardreader inside the G5X isn't the problem.
Anyone else experiencing this?
@Boejakasja wrote:
I dont want to format the card, card works perfect in laptop, other canon camera, and other devices so I assume the card itself s not the problem,  i want to keep the data in the card so format is a nogo
Buy a new card, and format it in the camera.  Do not use the memory card in the camera as a storage device, either.
8 REPLIES 8
Peter
Have you low level format the card in camera?
The card inserted is the same card as my D1300, in the D1300 no problem, in the G5X "memory card error"
What about my question?
There you have at least one problem.
I don't understand this repy
Buy a full-size SD card and try it in the G5X, if it does not work return the new G5X for a refund, or an exchange.
