08-02-2023 01:31 PM
I am trying to have my flash on at all times but I’m confused on how to have it on always what do I do ? I clicked funct. Setting I don’t see “p” I’m confused
08-02-2023 08:54 PM
See this in the camera's manual to have the flash fire all the time:
08-02-2023 08:58 PM
when I press “ func set” these are the only available options for some reason.
08-02-2023 09:00 PM - edited 08-02-2023 09:02 PM
There is a P mode:
You should probably download the manual and read up on your camera's features:
https://gdlp01.c-wss.com/gds/2/0300022092/01/elph360hs-ixus285hs-cu-en.pdf
08-02-2023 09:10 PM
Please re-read the steps to turn the flash on all the time. You have to press some buttons before pressing the set button. Did you download the manual and read up on what you are trying to do?
08-02-2023 09:50 PM
Press the lightning bolt button (right arrow button), select the flash mode ON, then press set function button.
08-02-2023 09:52 PM
Just got it. Thanks so much I truly appreciate the help !
08-04-2024 03:14 PM
I have the exact same problem!!!! I have been looking for a solution for a year but no one has been able to help me. To this day I am still trying to find the problem. Tell me if you fix it please!!!!! Thank you
08-04-2024 03:24 PM
Look at the image posted by Anonymous. Your top switch must be all the way to the LEFT white camera icon, not the green one. Then, tap the right arrow (lightning bolt). That will cycle you through the flash options of always on, always off, or auto flash.
