02-03-2019 10:26 AM
At zoom levels approaching max. optical and into digital zoom the camera fails to auto-focus (but does so at zooms below 50X). I’ve tried many of the permutations of focus settings, and read earlier posts relating to similar issues, but have not found a solution. I have been working with plenty of light (ISO 200, shutter speed 1/250 and up, and within the aperture range of the camera).
Suggestions?
Thanks...
02-06-2019 12:39 AM
02-06-2019 04:01 AM
@dbhuff49 wrote:
Here's one I took @ full optical zoom mid day had held no filters.
Hi - I'd like to see it too? - Where is it?
Cheers
G
02-06-2019 07:06 AM
@ojreichman wrote:Waddizzle - any thoughts about the removal of the polarizer affecting the focus, other than just (just?) increasing the light a couple of stops?
Thanks, Jim
Many image sensors work by comparing contrast on different phases of light. A polarizer removes out of phase light. I have had a couple of DSLR lenses that did not like CPL of UV filters. All I use now are CLEAR protective filters on lenses.
Suddenly, all of my colors improved.
02-06-2019 12:16 PM
Interesting, thanks again.
04-17-2019 08:52 AM
04-17-2019 08:55 AM
04-19-2019 07:41 AM
04-19-2019 10:29 AM - edited 04-19-2019 10:50 AM
SX60hs. Shot through green foliage. Blue London Skies. CircPola. Hand held. Chimneys 80 metres away. Auto Focus popped then shot. Look at the detail on the TV antenna, I can almost make out the threads on the Wing-nut bolts!
