09-18-2016 03:42 PM
New SX60 flash is not working in any mode. In Program mode I have the flash set to always fire. I verified all the flash menu settings. I inspected the external flash hot shoe and the small pressure switch seems to function fine. I used an external flash and it fires as expected. Any ideas?
09-18-2016 04:40 PM - edited 09-18-2016 04:41 PM
What external flash did you use?
If it is not a setting or the tiny switch in the hot shoe rail is not stuck then you have an internal problem which will require service hopefully under warranty.
Just for drill try performing a reset to defaults thruogh the settings menu too
09-18-2016 05:55 PM
The external flash is an ancient one I had from film camera days.
I forgot to mention I did a reset as part of my trouble shooting. I contacted Canon support and they had nothing to suggest. They just said send it in and they'll look at it.
I guess that's my last option.
thanks for trying.
09-18-2016 06:00 PM
Yes sending it in would be the only thing left and unless the flash you used was on the list of suggested flash units it will void the warranty if any. Since you said film days I doubt it is.
09-18-2016 06:06 PM
Good to know, but the internal flash never worked. The external flash was tried to see if the camera was even trying to flash. They better cover it.
09-18-2016 06:07 PM
Yes just dont provide them a reason not to cover it if you know what I mean
09-18-2016 06:09 PM
10-4. Thanks again!
09-18-2016 08:00 PM
Your welcome and good luck to you
