SX540 Double Pictures
robert91
When I take pictures with my SX540 I often get two of the same picture. Is there a setting that I can use to turn off this feature? Admittedly, I don't use the camera very much, so I probably ought to read the manual every time I use it. I keep the setting on top on the running man all the time, if that makes a difference. Thanks
1 REPLY 1
rs-eos
Are you perhaps capturing both RAW and JPEG? While you should be able to turn that off (e.g. capture JPEG only) I would strongly recommend continuing to capture RAW since if you ever want to edit your photos, you’d have the greatest flexibility.
Ricky
