07-23-2014 02:54 PM
I purchased a Powershot SX50 HS about three months ago and have been using it daily without issue. Yesterday when I powered it on, the view screen was half black on the left side. When I changed the display position, the black screen switched to the other side (the right side appeared black). When I tried to use the viewfinder, the same issue appears (left half of the screen is black). Is this a setting problem or a repair issue?
07-23-2014 08:27 PM
Sounds like a repair issue unfortunately. Haven't heard too much about this being an issue on the SX50's.
07-23-2014 08:45 PM
You can try and perform a "Reset All" thorugh the menu and hope that is was just a software gliche otherwise it will have to be serviced and in your case it should still be under warratny.
07-23-2014 08:51 PM
Thanks John. Unfortuately the "Reset All" didn't have any effect.
