11-15-2016
10:33 AM
09:08 AM
I have been trying to shoot pictures of the moon and having lousy results.
First I tried AUTO, which was sort of OK. The problem is when I depress the shutter the sharpness of the picture is less than before I press the shutter to check focus. The resulting image is not what I saw.
I looked online for a few ideas and tried some manual shots at f/5.6, ISO 800, speed 1/250. Again, I could see what seemed to be a pretty good image, but as soon as I pressed the shutter a little, the moon turned white. Tried it several times while using a tripod. Reduced the ISO to 400. Nada. Did not try setting the self timer - didn't seem like that would help.
Went back to AUTO and did get some shots, but again, not as clear as I expected when I pressed the shutter.
Very frustrating.
Obviously, I am new to this.
Thanks
11-25-2016 06:36 PM
Yes, trying to see if the Sigma 150-600mm is worth buying, or could I achieve the same results with the Powershot, since the 21-1365mm is optical, and not digital zoom. The Powershot has a smaller sensor, so I assume that would come into play, but if the differences are minimal, it is cheaper to get the Powershot....and a lot less lense to lug around. However, if there would be significant difference in sharpness, then I will dig deep and buy the Sigma. I mostly do potrait, both senior and family for income, but do enjoy nature shots, which would include eagles, snowy owls, sand hill cranes, etc...all of which are out of range of my current 250mm lens. Yes, I am sure the Powershot would be a step up from the 250mm, but if it is just a waste of money, I'd rather save a little longer and get the Sigma, but if the differences would be minimal, then why waste the money?
11-25-2016 07:11 PM
@Michelle1 wrote:Yes, trying to see if the Sigma 150-600mm is worth buying, or could I achieve the same results with the Powershot, since the 21-1365mm is optical, and not digital zoom. The Powershot has a smaller sensor, so I assume that would come into play, but if the differences are minimal, it is cheaper to get the Powershot....and a lot less lense to lug around. However, if there would be significant difference in sharpness, then I will dig deep and buy the Sigma. I mostly do potrait, both senior and family for income, but do enjoy nature shots, which would include eagles, snowy owls, sand hill cranes, etc...all of which are out of range of my current 250mm lens. Yes, I am sure the Powershot would be a step up from the 250mm, but if it is just a waste of money, I'd rather save a little longer and get the Sigma, but if the differences would be minimal, then why waste the money?
I love the Sigma 150-600mm Contemporary for almost everything I use if for. I am disappointed by it when I dial in 600mm, where the focus seems to be soft. I have to dial it back to 500mm for sharp focus. Cropping makes this point entirely moot.
My other complaint with the Sigma 150-600mm Contemporary is that focus seems soft at infinite focus. My jury is still out on this issue, but I keep coming up with soft images at 600mm, and the same shots are sharper at 500mm.
11-25-2016 07:46 PM
Great, I will keep that in mind. I also assume, since it is a 5-6.3 it does not fare well in low light, the Sigma that is?
11-26-2016 09:29 AM
@Michelle1 wrote:Great, I will keep that in mind. I also assume, since it is a 5-6.3 it does not fare well in low light, the Sigma that is?
I wouldn't quite put it that way. Low light performance really depends more upon your camera body.
The lens can capture great photos of the Moon, which means shooting in low light. The lens is designed for outdoor wildlife photography, sports photography, and other types of outdoor action. The lens has a Minimum Focus Distance that's over 20 feet, which is a distance not often found indoors. Can it be used indoors? I'm sure it can in well lit arenas and gyms.
Also, shooting at f/6.3 requires a lot of light to shoot at ISO 100. This is a given. The lens does very well in a variety of reduced lighting conditions, most especially if your camera body can capture good images at much higher ISO settings.
This was shot just after sunset with a 6D, 403mm, 1/800, f6.3, ISO 1250
11-27-2016 09:09 AM
Super disappointed with the rodeo photographs. Will post another question about action shots on a cloudy day.
05-17-2017 04:28 AM
05-17-2017
10:34 AM
11:38 AM
Please open your own topic on this. [New topic found HERE.]
08-19-2024 06:44 PM
The same happens to me. Using Canon SX60HS. I see the full moon with lots of details through the viewfinder. When I press the shutter, even with the timer, the image becomes whitish. Then it goes back to being sharp.
08-20-2024 12:19 AM
First, let me concur with my colleagues offering help: it is better if each different person starts their own thread because the specific circumstances of their camera setup, the conditions they shoot in and their technique may vary considerably, thus demanding different advice and solutions for each.
For those of you struggling with exposure or focus, I recommend reading the following primer on the subject:
Light, Dynamic Range, Metering and Exposure
You should read this in conjunction with your camera's user manual, in this case the Canon PowerShot SX60HS for which I enclose the following link: pssx60hs-cu-en.pdf (c-wss.com)
08-20-2024 09:06 AM
You should start your own topic.
You need to lower the exposure. See some of the other posts about the "looney 16" rule.
