PowerShot G9 X - Infrared Filter Specs Needed
imagesbyirwin
I'm planning to convert the camera to infrared and need the filter prior to disassembly. Does anybody know the size of the inside filter?
Thanks in advance.
4 REPLIES 4
normadel
Do you know such a filter for the G9X  exists, and that disassembly by a mere mortal is feasible to put it in?
I'm in agreement with Normadel.  I would not attempt to modify the G9x.  I found a tutorial for doing it but you have to perform AF calibration after the filter is replaced.  If done incorrectly, it may render your camera inoperable.
Taken with an Olympus Infrared converted MFTTaken with an Olympus Infrared converted MFT
The lens is stuck and since I was going to have it repaired, I wanted to convert it to a dedicated infrared since it was an older model.  I've done this before with an Olympus MFT. The repair person wanted me to get the filter prior. Appreciate your reply and concern.
