03-11-2024
11:21 PM
09:17 AM
Hello, I currently have the canon g7x mark ii and I’ve bought two memory cards but every time I try taking pictures it doesn’t let me and keeps saying memory card locked even when the switch on the card is unlocked. It’s been so frustrating, does anyone know how I can fix this? It won’t even let me format the sd card.
03-13-2024 12:01 AM
The "switch" on the SD card is not the actual switch that locks the card. It is a slider that presses on the real switch in the groove the card slides into. See if you can see the switch in the groove. If it is stuck down, the camera thinks any card is locked. Give it a nudge with a fine-pointed tool to see if it pops up.
If you can't manipulate the switch, the camera needs repair. It's seven years old. You have to find out if Canon still repairs it.
03-13-2024 12:56 AM
I am trying to see what switch you’re talking about but I don’t see it?
03-13-2024 11:56 AM
It IS way down in the slot, and it doesn't stick out very much. You need a flashlight to see in there. But if you (or someone else) don't see anything in the slot that would be pressed by the card, that could be your problem.
Do you have a camera-friend or a camera shop to help you? Otherwise, it's the repair option.
03-13-2024 12:07 PM
I tried taking a look with a fine tool but idk if that messed it up even more because now it says memory card error instead of memory card locked… I made an appt to take it to Best Buy this weekend to get it checked 😔
06-29-2024 12:00 PM
Hi! I am also having the exact same issue with my canon g7x mark ii. Was Best Buy able to help you? I want to send it in for repairs but it’s so expensive! Please let me know what you ended up doing
12-05-2024 02:34 AM
Hi! Any luck with this? Did you end up going to Best Buy as well
02-18-2025 03:02 PM
Hello I took it to Best Buy and they told me they couldn’t fix it !! I’m having the same issue ?? Did they quote you on canon how much was it ? I’m going to ship mine out
