09-11-2026
05:35 PM
08:42 PM
Tiffany
We have a power shot digital camera that has pictures on it but we can't get to the transfer menu to get the pictures onto my laptop. The support has ended so we are hoping someone on this forum can help us get the pictures off the camera.
Thank you,
Dave
09-11-2026 06:32 PM
What have tried? What computer do you have?
A card reader - which your computer may already have- is the easiest.
09-11-2026 06:32 PM
09-12-2026 11:44 AM
I’ve used the USB cable to connect the camera to my laptop - which has windows 11 installed.
we thought about card reader, so I guess we’ll purchase one and try that.
thank you
09-13-2026 02:21 PM
So, what happened /didn't happen when you used the USB cable? The camera should appear as a drive.
09-13-2026 05:35 PM
We could not get the transfer menu to appear - so we could not get the photos off the camera.
we did purchase a card reader - got that today and that worked.
thank you everyone for your help!
09-13-2026 05:44 PM
There ISN'T a TRANSFER MENU. The camera appears as a DRIVE in Windows File Manager. It has the camera name. You open it and there will be a DCIM folder. That's where your pictures are. You're seeing the same thing using the card reader. You open the card reader and there's the DCIM folder.
09-13-2026 05:55 PM
The documentation showed a transfer menu.
But the camera did not show up as a drive when connected the cable either. The card reader worked and we did see the DCIM folder and the pictures within another folder under that.
thanks!
09-13-2026 09:43 PM
The transfer menu would t be a part of the Canon software that you can install. It doesn't happen just by connecting camera to computer.
If the camera doesn't mount with a USB cable, it could be because the cable is bad or the USB port on the camera is bad. But since the card reader is working, it doesn't matter. Be happy.
