08-02-2024
01:41 PM
01:46 PM
Hi, i’m currently having the same problem. I have the ixus 60 and have tried an old and new SDHC cards. I have also tried them in a different camera and these SDHC cards work fine. Does the ixus 60 not take SDHC or is there something wrong with my camera?
thank you.
08-02-2024 01:44 PM
The manual will be very clear as to which cards to use. Also, make sure to use full size cards and not a micro card with adapter
08-02-2024 01:50 PM
Your camera only takes SD cards "tested up to 2 GB"
08-02-2024 02:59 PM
SD cards that are larger and faster than what the camera needs should not be a problem, but there may be a limit.. The specs say "tested up to 2 GB" because 18 years ago (when this camera came out), 2 GB was a "large" size. It may well take 4 or 8 GB cards. But that big is overkill, capacity-wise.
You don't say what size your cards are, but if they work fine in another camera, I'd say your camera is the culprit.
08-02-2024 03:11 PM
But I am pretty sure that SDHC, SDXC and SDUC are right out, they have more differences than just size.
