How do I set the SX 500 shutter speed
Namvetdem
Just started using my SX 500 Powershot and want to learn more about manual settings specifically setting shutter speeds.
2 REPLIES 2
cicopo
The manual is your friend & it should cover (with samples) this but to start with Shutter Speeds are the same as Tv  (in Canon lingo) which is Time Value. Av =aperture setting & M is for full manual operation where you select both the Tv & Av based on the light meter reading. I also highly recommend finding the section on Exposure Compensation & learning how to use it by instinct.
Thanks a bunch.  Understanding the lingo is a first step.  I'm getting there.
