09-15-2024 10:11 AM
I'm currently abroad in Austria and I left my camera charger at home. I was thinking of buying a European-type charger, since I will be here a while. But, I am not sure if this will fry my battery. Are Canon batteries dual voltage? I just want to make sure I won't need a converter!
09-15-2024 10:26 AM
If you purchase a Canon charger, you should see that they work worldwide. You should also see that the output of the battery charger should meet the input requirements of the battery. Since we're a global brand, we don't make the batteries different for other regions; only the plugs are different! 😊
09-15-2024 03:13 PM
Hi Emma - Welcome to the forum and also 'down under'!
Canon chargers come either with a socket for a two-wire cable for the local region, in which case you simply change the cable that you buy in Oz for a US one when you get home, or they will have the two-prong configuration to directly plug into an outlet for the region in which you purchase the charger. In that case, when you get back home, you can just use a basic adapter to change the pin angle.
As the respected moderator Stephen noted, Canon chargers will otherwise work on any international voltage and still render the correct charging rate to the batteries you put on them.
