Canon Powershot SX60 HS or comparable
johnwyork
I am a hoping someone can help me with the macro function of this camera.  I have heard nothing but good things about the macro functionality of it.
I am hoping to use this camera mostly for 2 functions which I hope can be saved as C1 and C2, easier for me to teach my dental assistants how to use it that way.  For C1, I am needing to get really up close and personal with the front 2 teeth, and for C2 I am needing to do the full smile with a larger depth of field.  I currently use a large Canon SLR body with a ring flash, but the assistants are intimidated by the size of this camera, and after I heard of this one, I've invested in it, but not sure how to set it up for these 2 functions.
If anyone can help in anyway, I would be very, very appreciatvie!
Thanks sincerely!
John York
4 REPLIES 4
TTMartin
Thanks sincerely!
John York
I think lighting will be an issue with that camera.
I think a better choice for a less intimidating set up would have been any of the EOS M line of cameras with the EF-M 28mm f/3.5 Macro IS STM with built in Macro Lite.
ef-m
I'm not a professional photographer, just someone who takes snapshots.  Keeping my "qualifications" (or lack thereof) in mind, I think you can get the results you want by just using the camera's lens in its "normal" mode while taking advantage of its zoom capablities.  i.e., step back a couple of feet from the subject and zoom in on the part that you want a close-up of.  If this method works to your satisfaction,  you should be able to better control your lighting conditions.
Marynthe
Hi John,
I'm a dentist  and I want to buy a camera for dental photography. Can you recommend the Canon Powershot SX60 HS? And have you figured out  a good set up for this camera? Thanks in advance.
Marynthe Tijink
@Marynthe wrote:
Hi John,
Marynthe Tijink
Mary,
NO the SX60 is a aweful camera for a dentist.
Almost any dental setup you look at it has a ring-light flash.
An EOS M (any model) and the EF-M 28mm f/3.5 Macro IS STM with built in Macro Lite is the small lower cost set up of choice for a dentist,
ef-m
This macro lens (close up lens) had a ring flash built into the front of it. It is a unique lens only made by Canon for the EOS M line of cameras, and is ideal for dental photography.
