12-02-2019
07:04 PM
02:13 PM
I have had a Canon Powershot G15 that I purchased for dental closeup photography though wish to use ring flash I do not own just yet. So far I purchased an FA-DC58D Filter adapter for it but still need a couple more parts. For one was told I need a macrolite adapter which I have on order. Also not sure but think I need a 250D macro closeup lens? Last but not least need a ring flash. The Canon made ring flash I found costs as much as the camera so probably want to buy a generic to keep it afordable. So was wondering if anyone has part recommendations to finish this setup?
Thank you.
PS: Found on amazon the Neewer Macro TTL Ring Flash Light with LED AF assist lamp for Canon E-TTL TTL Cameras. Its $80 and affordable. Would it work on a Powershot G15 though?
[link removed per forum guidelines]
Thanks again.
12-02-2019 07:35 PM
@moheban79 wrote:Hi,
Thank you.
[ LINK DELETED ]
Thanks again.
I do not recommend attaching weight devices to the front lens element, as it can strain the AF motors. Once those go, then camera is shot. If you are taking "dental shots" then I would assume that you have one of those "dental spotlights",
Could you use that? You could take hand held shots, or with the camera on a monopod for stability.
Does the camera have a macro mode. The G15 would not be my first choice for this type of macro photography. The least costly setup would be a Canon Rebel camera with the EF-S 60mm f/2.8 Macro STM lens.
12-05-2019 12:36 PM
Since you have a business and can count it as a business expense, why not use a Canon EOS M-series body (lots to choose from - some more compact than others) with the EF-M 28mm Macro lens, which has a built-in ring flash.
12-05-2019 12:54 PM
12-05-2019 12:59 PM
As you stated you were doing "dental closeup photography", it was not unreasonable to assume that you were doing it as a business. As most people would not choose this as a hobby, is it for academic purposes?
12-05-2019 01:00 PM
@moheban79 wrote:
Who ever said I have a business. Trying to use what I have. Limited funds. Thanks.
How limited are your funds - i.e. what's your budget?
12-05-2019
01:34 PM
01:39 PM
Stephen
I found this - not knowing your budget I can't say whether it is suitable but it IS designed for dental work and for the G15
[Removed link per forum guidelines - not well known company, has link to buy product. Name of product is "Doctors Eyes."]
12-05-2019 02:02 PM
@Tronhard,
Thanks for the tip. I looked them up and that ring flash would be perfect! Hopefuly its not too expensive as like I said limited funds.
Thanks!
12-05-2019 02:11 PM - edited 12-05-2019 02:13 PM
The site indicated a price of $65, I believe - oops that was for the case. sorry
12-10-2019 11:39 AM
Found that Doctorseyes Flash on B&H
https://www.bhphotovideo.com/c/product/1025776-REG/doctors_eyes_de_86cs_compact_system_with_led.html
Just seems very expensive. I mean for that kind of money I might as well get the Canon -MR14EX Ring flash...
Thanks
