05-21-2024
07:42 PM
09:26 AM
Today, I offered to copy a bank statement for a friend using the document feeder. I thought it would be easy as putting in the pages, choosing copy and two-sided printing. However, it pulled in all 3 pages but only printed the first page double sided and stopped. Tried several other two-sided options to no avail. According to the manual it is possible.
TIA
Printer : Canon MF753CDW
07-05-2024 11:27 AM
Going by memory, I knew the 753 was single pass duplex in the ADF. > One-pass 2-sided Scanning
There are 2 ways to achieve a single pass duplex scan. The setting should apply to all pages if loaded at once.
If you are using the MF Scan Utility and select the computer icon top left, you can set the default behavior for scans. The same applies for the Printer icon, which sets the default scan / copy settings when scanning from the printers LCD. This one can be overridden on the printer's LCD.
If you are using ScanGear
~R5 C (1.0.9.1), ~R50v ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8 ~CarePaks Are Worth It
07-04-2024 04:08 PM
Does anyone know how to do this?
07-04-2024 08:45 PM
I'll look into this for you later this evening. Are you performing the copy operating from the printers control panel, MF Scan Utility or ScanGear?
07-04-2024 08:57 PM
Thank you. I tried from the control panel and the software. They both did the same. For number of copies, I tried 1 and then tried the number of sheets I was copying. Of course, it just copied both sides of the first sheet 3 times which I expected..
07-05-2024 11:27 AM
07-07-2024 11:20 AM
Thank you, will have to remember it for new time. Sorryy it took so long for a response but am not being notified.
07-07-2024 11:48 AM
No worries. Busy time. The Independance holiday is for family and friends.😄
