08-10-2024
12:49 PM
01:06 PM
SamanthaW
Please can you tell me where to set double-sided printing for the 656 and where to turn it off. I've turned it off previously but today for some reason it's started printing double-sided again. When I go to the portal, both User and Admin, it shows the setting as off, so what am I missing?
Thanks
08-10-2024 01:07 PM
Greetings ,
I suggest you leave double-sided printing on in the Remote UI.
Where you want to control this feature is in the printer driver or from the LCD panel If you were copying something for example.
The printer driver allows you to select single side or duplex printing. The driver will remember the settings you used last, so if you want to change it all you have to do is click a box or a button.
What operating system version and build are you using the printer with?
08-10-2024 12:52 PM
Thanks for joining the conversation, proussak!
So that the Community can help you better, we need to know exactly which Canon printer model you're using. Do you have the imageCLASS MF656Cdw or something else with the number 656 in its name? That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
08-10-2024 12:58 PM
Sorry, it's the imageCLASS MF656Cdw
08-10-2024 01:07 PM
Greetings ,
08-10-2024 01:12 PM
Thanks for the reply - I'm on a Mac running 14.6.1.
So where do I change the settings in the driver?
08-11-2024 02:59 PM
I remembered how I'd done it in the past - in the Printer pref pane, the Options & Supplies button. But I would love to know (i) why the portal has a setting too if it's just not going to work, and (ii) why the setting in Options & Supplies got reset (but that's probably an Apple question not Canon).
Thanks anyway
