01-08-2025
08:32 PM
08:45 PM
Tiffany
How do I change the default folder scan documents are saved to using the MF654cdw? When I scan using computer utility, I have the option to select a folder each time. I would like to save the same folder as the default. When I scan directly from the MF654 I do not have any options where to save. Is there a way to change default folder on both my computer AND the MF654? I have Windows 10.
Thanks
01-08-2025 08:36 PM
Login to the printer's remote UI. Click on address book and configure a save to destination. This will be the name of a computer and path to a destination "save to" folder
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
01-08-2025 09:40 PM
Thank you for the reply. I had tried to set up remote UI but the IP address is not recognized.
01-09-2025 02:32 PM
Did you enable the Remote UI on the printer's LCD control panel?
01-09-2025 07:45 PM
Yes and I just went through menu to make sure and tried to aceess and
took too long to respond
01-09-2025 09:28 PM
The error you're getting indicates that the IP address may be incorrect.
Login to your router. Look at the list of attached devices and confirm the IP address assigned to the printer While you are there, I suggest you reserve or assign a static IP address.
Once complete. Power cycle the printer and attempt to visit it's webserver using the IP you assigned previously.
