03-30-2020 07:47 AM
Is there a way to configure this printer to printer from the only tray available by default? When I print from my phone I select Letter as the paper size and the printer has letter loaded in Tray 1 and it is configured as Letter in tray 1. Why doesn't it just print? Every time I print from a non-Windows device I have to walk to the printer to select the tray to print from and there is ironically only one option to select from on the printer.
04-01-2020 04:10 PM
Hi scottlindner.
Thank you for finding this issue. Were you using the Canon Print Service, the MOPRIA Print Service, or the Default Print Service when printing from the phone? You may need to disable the Default Print Service to prevent misprinting with either of the other options.
I look forward to your response.
03-31-2020 04:20 PM
Hi scottlindner.
For printing on Mac OS, you may set the paper source options in the Printer's settings window, Options tab.
For mobile devices, you will need to refer to the print options in the app from which you're printing.
04-01-2020 08:21 AM
I have done that on my Samsung S10e. In the print dialog I select Letter and it still prompts me on the printer to select the only option available which is Tray 1 which is letter. Here is a screenshot of my print screen on my phone and what it produced on my printer.
It won't print until the select the only option available which is Tray 1 LTR/Plain
04-01-2020 10:51 AM - edited 04-01-2020 11:26 AM
OMG I just figured it out. It works if I change the paper weight to 18lbs even though the paper weight is 24lbs. Which is terrible because I'm pretty certain the printer is using the paper weight to alter the bonding termperate used when printing.
Is there a way to solve this so I can specify the proper paper weight in the printer settings such that Letter = Letter rather than this very limiting Letter != Letter situation?
04-01-2020 04:10 PM
Hi scottlindner.
04-02-2020 08:35 AM - edited 04-02-2020 08:36 AM
I'm using Default Print Service. I just tried the Canon Print Service and changed the paper weight back to what it was and it printed fine from my phone although with a warning that it was sending it through your servers which is completely unecessary since I'm on the same LAN.
Thanks for the help. This solves my problem.
12-30-2020 03:01 PM
On my Debian machine, my printer appeared by itself after connecting it to my local network. However, I experienced the same issue of having to walk to the printer and select the printer tray (even though there's only one) using the default printer settings. I fixed it by changing the "Media Type" from "Auto" to "Stationery" via my Debian system's "Printer Properties" for my MF445dw.
